An odd Engine
Mike
11-26-2001 09:13:43
My uncle gave me a small engine and have no clue to what make it is. He said when it was put in the shed it ran but i'm not sure. It kind of looks funny because from just looking at it looks like the crankshaft is way above the oil level but maybe theres a dipper and the cylinder is horizontal. The crankshaft is also horizontal. The Carburetor is bolted to a 90 dergree elbow bolted to the block. On the head is a name plate which has a lot of info. First on top it has the name Busy Bee and says its 5 hp and runs at 2600 rpm. The name plate also says its got a 2 3/4 inch bore and 3 inch stroke, and a minimum gas octane of 67. Theres no gas tank on it but says its 2 gallons. The crankcase is 1 qt and a spark plug gap of .025 inch but there's no spark plug in it. If you know the spark plug to it give a hollar. Its also got instructions to start it. First, to start open the needle valve 1 1/4 turns out, which ever one that is! To stop press the grounding strip to the spark plug. Theres also a warning that says to drain the oil every 50 hrs. At the bottom of the name plate is the model number which is model AB with a serial number of 3 - 10what looks to a weak stamped 5 and 05(Model AB 3 - 10 05). Below all that at the bottom it says Gladden Products Corp. Glendale 4 Calif. And yes theres a four in there. I'm not sure where the motor came off from but there's a 3 belt pulley on the drive shaft. Also the shroud that goes around the flywheel is missing and to start it there's a notched pulley bolted to the flywheel to pull with a rope. Any help would be appreciated! Mike
john nelson
11-30-2001 16:14:45
 Re: An odd Engine in reply to Mike, 11-26-2001 09:13:43
i believe there was a engine called the busy bee. you might try harrys old engines on the web, he has a lot of info and links, if you dont find anything let me know, my neighbor does a lot with flywheel engines
tony
12-18-2001 07:50:00
 Re: Re: An odd Engine in reply to john nelson, 11-30-2001 16:14:45
hey mike its me
Jim Cavanaugh
01-19-2002 22:06:03
 Re: Re: Re: An odd Engine in reply to tony, 12-18-2001 07:50:00
Your engine is a Model AB. It was an industrial engine built in Glendale California. The 3-belt pulley is a clue that maybe it was equipped on a Jaques Power Saw. I worked at the factory on the engine line. The AB model was obloleted and replaced a whole new line including a version for the famous Mustang Motorcycle. I could help you with some answers. Good Luck!....Jim Cavanaugh
