Wisconsin AGND carb question
Dave K
11-26-2001 19:42:04
I have a Ditch Witch M422 with a Wisconsin/Teledyne AGND engine on it. The carb has a screw in the body at the top of the float chamber and a needle valve in the bottom of the carb float chamber. It idles fine but does not seem to go up to top speed. Can anyone tell me which to adjust for high speed and/or where to get a manual for the engine. Thanks in advance for any responses.
Charles Garner
06-15-2003 19:28:43
 Re: Wisconsin AGND carb question in reply to Dave K, 11-26-2001 19:42:04
Just bought one of those trenchers at a local auction here in Seattle. Mine is pretty well used up, but maybe we can figure the two machines out. I may have a manual on the engine, so send me your email address.
Robert Mauk
03-30-2004 09:51:14
 Re: Re: Wisconsin AGND carb question in reply to Charles Garner, 06-15-2003 19:28:43
I also need to know the timing on the 12HP AGND. Pulled the magneto off to clean it and don't have the specifics to re-install as the transmission is in the way of the "inspection hole" for the cam gears.
If you have the manual, could you scan and e-mail me the page(s) or fax to 309.213.0303. I'd apreciate it. Or if you want could you sell the motor manual or ship it for postage? I just rebuilt mine a few years ago but not the motor.
Also, did you get all the parts that go with it to widen the chain, etc., and the "trench cleaner?" I have the Ditch Witch M Series manual but not the Wisconsin one.
If you need it I will e-mail my voice number, too.
Thanks
Bob
Mick Kennedy
03-03-2006 05:03:19
 Re: Re: Re: Wisconsin AGND carb question in reply to Robert Mauk, 03-30-2004 09:51:14
I have a M422 trencher and would like to get hold of a copy of a manual for the machine do you have one. Can you assist I can send you a email or fax no I am in Australia
Regards Mick Kennedy
