Clinton 2-cycle questions
Zira
11-28-2001 17:09:46
I have acquired an odd-looking Clinton 2-cycle model VS200 2172. This looks like a small vertical shaft engine that was rotated so that the shaft is horizontal, and the piston is also horizontal. The gas tank is mounted on the top, and the carb is mounted such that it is obvious that the motor is meant to be mounted like this.
Does anyone have any information, especially owners manual, parts diagram, service manual? What type of oil/gas ratio should I use with modern 2-cycle oil? What were these used on?
Thanks.
Roe B. Lane
12-09-2004 14:29:39
 Re: Clinton 2-cycle questions in reply to Zira, 11-28-2001 17:09:46
Zira: I have the parts list for the VS-200-2172 $5.00 which includes S & H. Also have the Manual of Maint. and Overhaul Inst. this is for all Clinton Engines over 100 pages $30.00 which incl. S & H..I can tell you it was made before 1958 as this is the latest edition of the parts manual. Let me know if interested and will send you address to send check money order or cashiers check...Roe PS Have a few Clinton parts and can give you sources for others if I do not have.
bob jhonson
09-11-2003 23:56:39
what makes a power band? sum say it's were the intake is and exhaust or the amount of fule. or the carb i hve a scooter and it's a 2 cycle but it don't have a power band my friend has a scooter but diferent engine and it has a power band. so what makes a power band and how can i make one? thank hope u can anwser miy question bob.
Dale E. Smith
04-27-2005 22:25:54
 Re: Re: Clinton 2-cycle questions in reply to bob jhonson, 09-11-2003 23:56:39
A Power band, is the point from low to high rpm where most of the engine power is generated.
Engine design determines it. Especially with two strokes, it is adjusted by the height of the exhaust port and exhaust system. The lower the exhaust port the lower in the rpm range the power comes on, it also dies off, soon after it starts. With the exhaust port high in the cyclinder, the power comes on at high rpm, but has very little at low rpm.
That is why the modern two stroke dirt bikes have what is called power valves. They lower the exhaust port at low rpm and raise it at high rpm, this creates a very broad power band.
Kiel
05-01-2003 17:53:37
I have an engine like that, the 3 horse model. They were a popular engine made in the USA. They were popular for go-carts, and I have seen tham on lawnmowers. There is even an ad showing two of them mounted on the back of a go-kart. The series is called "Panther" They are a two-stroke wonder for carters. I have mine bolted to a motor scooter I've built.
Franz
11-30-2001 17:00:24
It sounds like what they called a go cart engine. I have one on a device called a Wards Clear-z-all, sort of an early version of a weed eater with a bad case of giantism. This unit came with a 10" 3 tip blade for clearing weeds. Options included a roto tiller head (small) a water pump, and a 10" saw blade. That thing would reduce a full grown man to his knees running it for half an hour.
