Mud pump diaphram
cj
11-30-2001 19:31:46
I am looking for a diaphram for a marlow water hog mud pump. Any suggestions on where I could buy one, or how I could possibly make one somehow.
Franz
12-03-2001 16:32:37
 Re: mud pump diaphram in reply to cj, 11-30-2001 19:31:46
I don't know where you're located, so telling you who th erubber supplier in your area is ain't possible.
Find a supplier in your area, and tell them you need a piece of diaphram rubber of whatever thickness that was, and they should be able to help you, unless that pump had a rippled diaphram.
Wastecorp
07-22-2005 19:25:00
 Re: Re: mud pump diaphram in reply to Franz, 12-03-2001 16:32:37
Parts to fit the Mud Hog / Water Hog Diaphragm pump is avalible through www.wastecorp.com
Tel: 1-888-829-2783
Jon
12-03-2001 15:33:26
We used a piece of inner tube to restored our mud pump.
cj
12-03-2001 19:01:47
 Re: Re: mud pump diaphram in reply to Jon, 12-03-2001 15:33:26
Thank you for the reply. How did you set up the rubber in the pump. Did you leave it tight across such that it stretches out every time the pump moves up and down, or did you leave some slack in it somehow. This was one of my thoughts, any more info would be great. I think the origonal pump had a ribbed diaphram, but seing that it went through a fire there is little left to compare to. Thanks a lot.
Festus
01-15-2003 20:34:54
 Re: Re: Re: mud pump diaphram in reply to cj, 12-03-2001 19:01:47
I was wondering where i could order a parts for a Marlow Mud Hog Diaphragm sewage pump
