Massey-Harris Type 2 ,1.5 hp
Rob (On)
12-10-2001 09:49:52
Hello all. I recently found a Massey Harris Type 2 1.5hp gas engine in a barn being torn down. Can't read the serial number or speed number. Also having trouble locating information about this engine. ID plate says manufactured by Massey Harris, Toronto, Canada. Is this a hit and miss or throttle governed? Current ignition is three bare wires and a piece of broken hacksaw blade. What should be there? Bottom of water jacket and part of cylinder freeze cracked,should be repairable. What do I have and what type of ignition is used? Any help greatly appreciated. Thanks, Rob
TAK
12-14-2001 06:36:49
 Re: Massey-Harris Type 2 ,1.5 hp in reply to Rob (On), 12-10-2001 09:49:52
Rob ~ The only reference that I could find on this engine indicates that 1923 models(first year production) were equipped with a webster low tension magneto and in 1924 a Wico high tension magneto was substituted and remained as standard equipment. Hope this helps!
Dennis
01-04-2004 15:42:15
 Re: Re: Massey-Harris Type 2 ,1.5 hp in reply to TAK, 12-14-2001 06:36:49
Rob Try searching Massey Harris engine registry. www.angelfire.com/ny/carrotpatch/MasseyRegistry.htm This site has type1, type2 and type3 spects. good luck
