Fairbanks-Morse Model Z 6 horse
Jason
02-27-1999 19:49:43
I recently aquired a 1918 6 horse power model z fm. I got it running but only by keeping the carb? if that is what it is call filled w/ gas by pouring it in by hand. There is a little lever on the front of the carb that looks like it rubs the push rod to pump fuel up from the tank. Kind of like an accelerater pump on an automobile carb. There is a little steel ball down in the carb below this pump arm. Is this where the fuel line hooks in under the ball? There is another threaded hole in the bottom of the carb next to this other one, is it a return line ? Also what goes between the ball and thepump arm, if that is what it is, Is there as spring? The only thing there is a little cap that fits in the top of that hole and the ball. Is it a fuel pump? There is also an adjust ment knob that goes into the water jacket on the head, what is this for? Thanks for the help, Jason
paul d clum
03-03-1999 22:09:11
 Re: Fairbanks-Morse Model Z 6 horse in reply to Jason, 02-27-1999 19:49:43
That is a very fine engine my son,,,, i know them inside and out,,,, what kind of mag is on there?
John Ross
07-07-1999 18:26:02
 Re: Re: Fairbanks-Morse Model Z 6 horse in reply to paul d clum, 03-03-1999 22:09:11
My dad just purchased an old FM model z. We're trying to locate the serial number. Any idea where it is located on the engine?
Thanks!
walter smith
10-05-2001 17:29:10
 Re: Re: Re: Fairbanks-Morse Model Z 6 horse in reply to John Ross, 07-07-1999 18:26:02
fine engine my friend.i have one railroad type
having trouble getting it to run.had run in the past but now i dont know where to turn.need a service manual,hard to find for a 44b fairbanks morse.maybe the boys know where to look.
thanks walter smith
