Timing Wisconsin VH series engine with a magneto
david
12-30-2001 11:24:03
I have a Wisconsin engine that I am having trouble timing. As far as I can ascertain, the engine is either a VH-4, VH-4D or a VH-4DM engine. I can't read the name plate as it is worn off. It had a Fairbanks-Morse magneto # FM JV4B7 magneto on it that developed a problem. One of the centrifical stops had worn out. So I swapped it for a Wico XH-1343 I had on hand. I had to swap the gear from the Fairbanks-Morse onto the Wico. This Wico's gear was rusted. I have attempted to time it by finding TDC on the #1 (left cyl. closest to the flywheel). It still is running like it's badly out of time. Any help would be greatly appreciated
Steve
12-30-2001 15:29:33
 Re: Timing Wisconsin VH series engine with a magneto in reply to david, 12-30-2001 11:24:03
If you can get me casting number on block I can tell you which engine you have and if you have right magneto for it.
Steve
12-30-2001 15:29:37
