AENL Wisconsin
William Freed
12-30-2001 18:50:37
I'm having a tough time get this engine retimed could someone offer detailed instructions on set mag with cyl @TDC
Ron Bullard
01-05-2002 19:12:02
 Re: AENL Wisconsin in reply to William Freed, 12-30-2001 18:50:37
I don't have specifics on your engine, but generally speaking timing the magneto is a matter of aligning the timing mark on the magneto gear with the timing mark on the gear that drives it. It's the same concept as timing the cam and crankshafts, a mark on the tooth of one gear lines up with a mark in the crotch of another. there's usually a plug you can unsrew to get a look at the point where the two gears come together and check out the alignment of the marks.
Hope this helps.
fransun
03-22-2002 21:08:37
 Re: Re: AENL Wisconsin in reply to Ron Bullard, 01-05-2002 19:12:02
to properly time your aenl wisconsin engine with the piston @ tdc you will align the timing mark of your crankshaft gear with the timing marks of your camshaft gear, and now the "x" marked magneto gear tooth must show through the inspection port that you took the screw plug out of on the side of the crankcase.
