Old army generator
uncletom
01-08-2002 11:58:38
help i have an old generator,its ODgreen,airforce blue.it is small. 2 quart round gas tank on blower cover,up draft carb.is all cast iron engine.two inch bore.one and a half stroke,the gen part is small twelve inch's or so,the numbers on engine plate are PC305207460 then 30546 under that is 008 015,any have any info I could use .thanks
Tom
01-22-2002 20:05:05
 Re: old army generator in reply to uncletom, 01-08-2002 11:58:38
Sounds like an old Briggs engine. The .008 is the valve clearance on the intake valve. The .015 is the clearance on the exhaust valve.
Joe
01-22-2002 17:06:09
I might have the same military engine.It's a two cycle,one cylinder olive drab unit.I bought the last military tech.manual for it from a military manual outfit.The manual is a TM11-1943,engine-generator PU-181/PGC-1.It delivers 300 watts and is 120/240 volts.It operates at 3600 rpm.The manual shows maintenance,repair and a breakdown of parts.The generator is single phase,60 cycles.Hope this helps.
