Olds model hit miss engine/ points help needed!
Bruce
01-11-2002 07:11:17
third party image
Looking for info or replacement breaker points
for this 1/4 scale model. I am anxious to hear this run. Thanks for any info! Bruce Cramer
ps, copy and paste in URL: Link
Jim Steelsmith
02-19-2004 10:19:46
 Re: Olds model hit miss engine/ points help needed in reply to Bruce, 01-11-2002 07:11:17
Did you ever get your olds model running? Take care, Jim
LynMn
01-13-2002 20:39:38
 Re: Olds model hit miss engine/ points help needed! in reply to Bruce, 01-11-2002 07:11:17
These engines were built from castings and the
prints called for points from a Clinton engine that used a Phelon magneto.It was up to the builder what type of points were used.I did not
use that type on my engine.You can take your points to NAPA store and ask to see the buyers
guide section of small engine ignition parts
catalog and find the right type. Or just clean
the points with fine abrasive paper. can not get photo
Bruce
01-14-2002 04:55:28
 Re: Re: Olds model hit miss engine/ points help needed! in reply to LynMn, 01-13-2002 20:39:38
LynMn, this is not a type of points I ever saw that
is used on this model. If you give me an email address I would be gratefull to send you a pic. I havent seen enough (1) of the models to figure how to make a regular points setup work on this. Thanks, Bruce
