IHC LB engine timing
Stevie
01-23-2002 15:29:57
Hello. Hope someone can help me out with timing the magneto to the engine. Took the mag off to do some work on it and am not sure about how to time the mag. Thanks in advance.
Stevie
Harold R. Stotts
04-23-2002 20:02:21
 Re: IHC LB engine timing in reply to Stevie, 01-23-2002 15:29:57
Thats easy. Just take the plug out and turn engine till both rockers are all the way out and use a wire in the plug hole and turn the engine till you feel the piston go all the way forward and as it starts to go back, rock it the other way till you got top dead center, then turn the mag clockwise till you feel a lot of resistance and hold it there till you get it to mesh the teeth together, bolt it in then watch it fire when you turn it.
walt f
01-23-2002 19:01:39
the operators manual (if you don't have one, get one)says "magneto may be timed to engine by placing "d.c." mark on flywheel in line with timing notch on side plate and inserting magneto into place, with marked tooth of magneto gear held in line with punch mark on magneto flange." try that. if you don't have any luck then get back, and we'll try something differen't----walt
