Fairbanks morse mag
bud sather
01-28-2002 20:14:29
I have a fairbanks morse type fmxd1b7 , serial number 2973448 mag that is on a wisconsin motor. I took the cover off that mag and it looks clean on the inside. I filed the points and turned the engine over. Sometimes the mag will spark and sometimes it will not. Sometimes there is that definite snap that a mag has and sometimes not. Anybody have a clue as to what is going on with this mag. I do not have any clue as to how long this motor has been sitting since it last ran but I think it would run if I could get constant spark. Thanks for any info you can give me.
Bud
Scott
01-31-2002 16:08:37
 Re: fairbanks morse mag in reply to bud sather, 01-28-2002 20:14:29
Sometimes filing points still does not make good spark i would get new points from your Wisconsin dealer.
Linda
01-29-2002 08:38:36
Either you trip on the impluse is worn, or the stop it catches on is worn or the spring is weak or broken. We would recommend replacing the complete impuluse unit.
bud
01-30-2002 07:07:38
 Re: Re: fairbanks morse mag in reply to Linda , 01-29-2002 08:38:36
Thanks Linda for the info.
