Help??
crazyman
01-30-2002 06:23:30
I have an old motor with the piston stuck, it has been soaking in trany fluid for about a year now, it still wont budge, what is the best way to break it lose? (the old man I got it from thought it was a old waterpump, not a motor)
Charlie
02-01-2002 21:57:23
 Re: help?? in reply to crazyman, 01-30-2002 06:23:30
depending on what it is you can push it out with hydralic pressure or if it is really bad you can heat the cylinder and then freeze the piston with dry ice and pull it out, with some more info on what your machine is maybe I can help you more
