Id numbers on 2 cyl wisconsin
Gurdy
02-02-2002 05:36:28
I have a 2 cyl. Wisconsin motor that I need to identify. I found ab-100 on the head (probably a casting number) and B AA96A on base of the cyl.
they don't seem to match any thing. where else do I look?
Sam Savage
02-03-2002 05:33:24
 Re: Id numbers on 2 cyl wisconsin in reply to Gurdy, 02-02-2002 05:36:28
AB-100 is the basic part number for a family of two and four cylinder Wisconsin cylinder heads. AB-100 fits a VH4/TH series. Older models had a suffix (AB-100-A, AB-100-B, etc.). My parts books indicate "-B" for the VE4/TE series, "-A" for the VF4/TE series. There's a lot of interchangeability between models, so it's possible that you have parts from several engines.
A few of the "T" series parts lists would be a big help for you. Available from EBAY, also online from WIS/CON.
Scott
02-02-2002 09:57:25
The I.D. plate was on the shield surrounding the cylinder part of the block.
Gurdy
02-08-2002 07:20:30
 Re: Re: Id numbers on 2 cyl wisconsin in reply to Scott, 02-02-2002 09:57:25
All the tags on the out side of the engine are gone... I need to ID this engine by casting numbers or some other way.
