Wisconsin vh4d
vg4d
BUBBA
02-18-2002 14:46:24
are the cylinder blocks interchangeable with these two engines i have a vh4d with bad exhaust ports
and a vg4d in good shape help!!!!!
d francoeur
04-10-2003 13:26:58
 Re: wisconsin vh4d - vg4d in reply to BUBBA, 02-18-2002 14:46:24
I'am looking for a cylider and head for a vg4d. Also I have parts for a vh4d
Greg
02-20-2002 06:50:10
Bubba.....I had a VF4D on a baler that some moron (me) installed a four foot straight pipe on and wallowed out the exhaust ports, which, of course, caused an exhaust leak. I got some exhaust gasket material, cut a ring large enough to go around the manifold and then bent the plates that hold the manifold tight to the head so that they would push harder on the manifold. Worked great, and, although I no longer own the engine, hear that it still works fine. I made this repair in 1969! This repair might be worth a try before you go the the trouble and expense of changing the heads (not an easy task on a Wisconsin, in my experience). Good luck and all the best....Greg
