Leader Field Force Pump Co.
Smoke
03-11-2002 12:16:51
I have a Leader 4hp Engine. it is hit & Miss. I am trying to get serial Number info on these engines. They were made in Elmira NY.
Thanks
John F.
03-20-2002 17:29:08
 Re: Leader Field Force Pump Co. in reply to Smoke, 03-11-2002 12:16:51
Yes, they were manufacturedbut the Field Force Pump Co. I've got a 3 1/2hp. There's a fella in NY that collects Leaders and has some information.
Here's his response to my inquiry about my Leader.
There is no existing factory list of manu. dates for this make, they went up in smoke in August, 1939. What I have is a compilation of serial numbers taken from existing engines. By comparing these engine numbers with design changes, a ballpark idea can be obtained. Yours is rated at 3 1/2 hp. They re-rated these engines to 4 hp about 1919-'21. The original 1908 HP was 3, being uprated to 3 1/2 about 1912-'13. Knowing this we can date your engine to this period of time. A good picture or two will help me more. There are other things that were changed and noted in F.F.P. Co. catalogs as improvements from year to year. We might be able to get closer on the date of manu. I am a dedicated Leader collector and have spent several years researching this company and it's products. I currently have 17 Leaders, no two alike. I also have two examples of the "Tayoga" engine they built. I own the earliest known Leader. I own the only throttling Leader known to exist. I have the most complete, extensive collection of these engines in the USA. I know Leaders inside out , up and down, over and back. I hope this helps you, Send me a pic or two if you can, I'll see what I can come up with for you.
Brian M. Lynch
Wellsville, NY
Brad Campbell
11-16-2004 12:48:33
 Re: Re: Leader Field Force Pump Co. in reply to John F., 03-20-2002 17:29:08
I'm looking for inf. on a Tayoga engine Ser # 2113, 1 3/4 HP. Any help would great! Brad (707) 485-5574
lewis
02-12-2006 06:08:59
 Re: Re: Leader Field Force Pump Co. in reply to Brad Campbell, 11-16-2004 12:48:33
I have a 4hp leader engine made by field force pump co. serial no. 2458 with a 5"dia cyl. its in exl cond. Can anyone tell me what it would be worth. donnie
smoke
03-30-2002 14:33:17
Thanks John, you are a big help. I have the wico mag setup on my engine my serial number is 3540 so based on your info I could probably put mine around 1924 or 25. Thanks, you made my day.
