Need a fix
H. Spencer
03-23-2002 09:39:38
A collector I'm not. I am somewhat mechanicaly challenged Iam cheap and Iam Canadian. I do have a THD Wisconsin sn# 3341548 2 cyl.that runs a hydraulic pump for a log splitter. It runs great, when I can get the #$!^*$ thing started. Are thereany secrets it's a hand crank regards Hugh
Larry from Maryland
03-26-2002 09:15:49
 Re: Need a fix in reply to H. Spencer, 03-23-2002 09:39:38
The one I have with the same problem had the intake manifold gaskets go to pieces and fall out.Before this happened,starting by hand was no problem.
H. Spencer
03-26-2002 17:00:24
 Re: Re: Need a fix in reply to Larry from Maryland, 03-26-2002 09:15:49
Larry from Maryland if you have the same engine do you know the year and HP. Ihave been trying to find out for some time now. Any help would be great. regards Hugh
