1st. JD Luc engine built when???
Dan
04-11-2002 14:45:02
Does anyone have any info when the first JD LUC was first made or what year they had their first application. Thankyou
Keith Ault
11-07-2002 06:22:36
 Re: 1st. JD Luc engine built when??? in reply to Dan, 04-11-2002 14:45:02
early JD "L" use the same type engine.The earlier ones were a IXB Hercules reduced to 2 cylinders.Later JD started making it own motor.The Hercules motor block and bell housing are 2 seperate pieces,JD,when they started making made unit in one complete piece.A friend of mine had a "L",we found a brand new 2 cyl Hercules on a "Bean" sprayer,took motor mount from Avery A and made fit,it bolted up to bell housing
Steve - NW Ohio
04-12-2002 17:52:21
I am not certain as to when the first LUC engine was built. I have never seen an unstyled "LUC", the first styled "L" was built in mid 1938. What seriela # is your unit, we have two of them.
Dan
04-13-2002 12:45:07
 Re: Re: 1st. JD Luc engine built when??? in reply to Steve - NW Ohio, 04-12-2002 17:52:21
Steve, my ser.# is C14788. I am not sure what application the engine had, when I got it, it was free standing. There probably is a way to determine thr year from the ser.# but I do not have that info.
Van(WA)
04-12-2002 07:47:41
Dan, What does "LUC" stand for????? ?
Dan
04-12-2002 12:30:23
 Re: Re: 1st. JD Luc engine built when??? in reply to Van(WA), 04-12-2002 07:47:41
Van, its a model name of a JD power unit used on JD combines and swathers. LUC is on the ser.# tag. The engine is a vertical 2 cyl. with a radiator and magneto. The one I have starts with a handcrank.
Roger Anderson
07-31-2002 13:22:50
 Re: Re: Re: 1st. JD Luc engine built when??? in reply to Dan, 04-12-2002 12:30:23
Hello,
I was wondering if anyone could tell me the timing settings for an LUC, my dad got one and we have been having a hard time getting it in time.
Thanks,
Roger Anderson
