Onan Help Needed
Mogman
04-18-2002 17:25:22
I have an Onan T260G engine that is driving a hydraulic pump off a front(flywheel) PTO. The "output" shaft is doing nothing. It has a "45BF" tapered shaft with no key, tapped in the center.
Have I not seen this same taper used on Onan generators???? I would like to mount a generator to this engine... 3 or 4 Kw would be plenty. I have seen lots of older Onan generators with horizontal twins and vertical singles, one and two cylinder diesels around (junk) in the 3-4 Kw class.. Would any of these mount to the T260G???
Does the end frame replace the out put shaft bearing mount???? Any information or where I could get the information would be greatly appreciated.
Mogman
Mogman
04-18-2002 17:29:18
 Re: Onan Help Needed in reply to Mogman, 04-18-2002 17:25:22
I forgot it runs at 1800 rpm, a small deviation from this would be ok, but I don't want to run it at 3600
Thanks again
Mogman
