What the @#$@ is wrong!?!
JDM Guy
04-20-2002 04:48:17
Hi every one,
I have a Briggs&Straton 3.5 hp push mower. Every time I lift up the front to turn around it starts smoking then it stalls and i can here bubbles forming in the carb. Then when I took off the air filter there was oil in the carb and it was running out the muffler. It has good compression and runs great under a load. Whats wrong?
Jeremy
04-20-2002 11:43:26
 Re: What the @#$@ is wrong!?! in reply to JDM Guy, 04-20-2002 04:48:17
Oil overfilled? If the cylinder faces backwards, being overfilled could definitely dump oil onto the back of the piston and make a big mess.
JDM Guy
04-20-2002 13:43:48
 Re: Re: What the @#$@ is wrong!?! in reply to Jeremy, 04-20-2002 11:43:26
Thank you very much!
I'll go down right now to check the oil level. By the way nice web site.
