BS Engine/Generator
Courtland
03-17-1999 06:13:47
I have a 4 horse Briggs&Stratton engine with a generator sold by Sears(oil wash air) back in the mid 40's-50's. I was wondring how to remove what looks like a "cup" with 3-screw holes for the screen which is on the pull shaft in front of the flywheel. This cup is hindering the removal of the fly wheel.
Tom
03-17-1999 16:38:03
 Re: BS Engine/Generator in reply to Courtland, 03-17-1999 06:13:47
I assume that the "cup" you are referring to is the ratchet for the starter pull rope. It screws on. Put the screw back into one of the ears on it to prevent distorting the hole, then lay a piece of brass against the ear and tap against it with a hammer. Once it starts to come loose, you can screw it off by hand. When you put it back on, tighten it by tapping with the hammer and piece of brass again. This time in the opposite direction. It screws off counter clockwise and screws on clockwise.
Courtland
03-18-1999 07:30:07
 Re: Re: BS Engine/Generator in reply to Tom, 03-17-1999 16:38:03
Thank you.
Tom
03-18-1999 22:07:49
 Re: Re: Re: BS Engine/Generator in reply to Courtland, 03-18-1999 07:30:07
You're Welcome
