32 volt battery for 600 delco light
Buzz Braude
04-22-2002 11:19:49
Does anyone out there have an easy solution to getting a 32volt battery hookup for a delco light plant?? Please email me at babraude@floodcity.net or call at 814 288 1839. Thanks Buzz
Will Simmons
11-01-2002 19:40:47
 Re: 32 volt battery for 600 delco light in reply to Buzz Braude, 04-22-2002 11:19:49
you can get 2-12 volt and 1-8 volt battery to make up the 32 volts needed. the 8 volt you might have to get at a battery specialty store. i have 3 plants i run set up this way. they are not meant to run all the time, like the hit and miss engines, as this would overcharge the batteries and possibly cause an explosion. they were only used to charge the batteries when the voltage was low after prolonged use.
mark pupo
08-09-2002 19:03:46
you can still purchase 8 volt wet cell lead acid batteries-you would need to go to a large battery supplier-i don't believe tracor supply or an ordinary auto parts supplier would have 8 volt batteries-4 of these would make a matched set and would equal 32 volts.....when in series..
good luck
Wayne Lile
06-29-2002 14:17:45
I would appreciate it if you would share any info you recieve. I recently got a delco-lite 32 v. and it will be my next project. Thanks Wayne
