Sea King 3.5hp Outboard
Ben Hunter
05-20-2002 11:18:24
Does anyone out there have any information on the above mentioned motor. I'm trying to get it started, but it stays in gear while starting. Should it? I've tried several different places for a manual and can't find one - maybe someone out there has one I could get a copy of - the motor was manufactured by Clinton Engines. Thanks.
john in mo.
05-21-2002 00:49:22
 Re: Sea King 3.5hp Outboard in reply to Ben Hunter, 05-20-2002 11:18:24
Hi Ben, I don't know about the sea-king, but a friend of mine bought an off market brand that I can't even prononce, it is air cooled and the prop is direct drive from the engine, when you crank the engine the prop turns. seems to run good thou. good luck on finding a manual.
ben hunter
05-22-2002 13:29:32
 Re: Re: Sea King 3.5hp Outboard in reply to john in mo., 05-21-2002 00:49:22
I found out that the motor is a direct drive. Do you know where I could find a solid state ignition for it?
ben hunter
05-21-2002 07:43:42
Thanks for your input. Now I need a solid state ignition for the same motor. Does anyone know if its still available, where I can get it, and about how much it costs?
