Compression for a BS 3.5
Jason
05-26-2002 12:04:10
I have a B&S 3.5 push mower that is 20 years old and has 50PSI of compression. What is the standard compression for this engine? Is there a rebuild kit available or do I have to get the motor replaced?
thanks
Don Young
06-10-2002 21:55:01
 Re: Compression for a BS 3.5 in reply to Jason, 05-26-2002 12:04:10
Compression readings on this type of engine tend to vary a lot and if you can feel the compression it is probably adequate. End of service life is generally due to excessive oil burning and/or knocking or other noises if the engine does not suffer a self-destruct. Individual parts should be available for a rebuild. Hope this helps, Don.
fzbcheve
06-19-2002 18:38:20
 Re: Re: Compression for a BS 3.5 in reply to Don Young, 06-10-2002 21:55:01
B/S say's that if you turn the blade backward, and can feel any kind of bonce, compression is ok.
