Continental model nubers where are they
Chad King
06-09-2002 14:25:44
Where are the continental engines model nuber located at on it. I have a 4 cyl. hooked up to a generator and I believe the motor is froze. I need to find the model number to get parts. Any help will be greatly appreciated
Don Young
06-10-2002 21:12:48
 Re: Continental model nubers where are they in reply to Chad King, 06-09-2002 14:25:44
If it is like the ones I have seen, there should be a metal tag riveted to the block on the side opposite the manifold, just above the oil pan and about halfway front to back. It may have numbers like F124, F135, F162, etc.. There are also some Y series and N series model numbers. All these are flat head engines. There are also some casting numbers which may help if you don't find the plate. Lots of Luck, Don
