How to test JD E 1-1/2HP engine magneto
Jeremy
06-13-2002 13:01:39
Trying to get an early model JD "E" stationary engine running for a friend. It doesn't want to fire at all. How do I go about testing/checking the magneto to see if it's producing power? I noticed the magnets on it don't put much of a pull on a wrench held up next to them. Can I check the voltage with a voltmeter while cranking? How many volts should I see?
Van(WA)
06-14-2002 07:35:10
 Re: How to test JD E 1-1/2HP engine magneto in reply to Jeremy, 06-13-2002 13:01:39
Jermey; You should see "spark" by turning it over by hand!!! Your magnets may need to be "re-charge" Have never checked one for voltage, just keep it simple, you can tell if you are getting a good spark.
Jeremy
07-11-2002 15:37:23
 Re: Re: How to test JD E 1-1/2HP engine magneto in reply to Van(WA), 06-14-2002 07:35:10
If anyone happens to read this late reply, I got the engine running. The problem was the oil pan had rusted through and the fuel was a nasty mix of gas, oil, and water. Once I fabricated a new oil plate/pan and sealed the inside of the fuel tank with a thin coat of JB Weld, she fired right up on the second spin. Pictures and two MPEG movies of the engine are at Link
