How do you unfreeze an engine
Joe mathews
03-20-1999 18:00:41
how do you unfreeze an engine
John in Pa.
03-21-1999 07:14:12
 Re: how do you unfreeze an engine in reply to Joe mathews, 03-20-1999 18:00:41
Joe, may be able to offer advice, but would like to know more about the engine; what engine, how many cylinders, is the piston stuck in the bore, etc?
Keith
03-20-2000 13:48:17
 Re: Re: how do you unfreeze an engine in reply to John in Pa., 03-21-1999 07:14:12
I don't have a tractor with a frozen engine, but a car. how would i go about unfreezing it?
p leblanc
01-27-2005 02:27:33
 Re: Re: Re: how do you unfreeze an engine in reply to Keith, 03-20-2000 13:48:17
Take all of the spare plugs out of the engine.
Pour about a tablespoon of oil into the cylinder and let it leak down the sides. Let the oil set in the cylinder for about 15 minutes. Turn the engine on several times. Put the spark plugs back in and fill with the correct amount of oil for that engine. That should unfreeze the engine and you will be able to drive it without having to buy a new engine.
86 camaro z28
02-09-2006 18:19:27
 Re: Re: Re: how do you unfreeze an engine in reply to p leblanc, 01-27-2005 02:27:33
i drove with no oil and my engine wont turn over how can i fix the problem cheaper then a new engine
ricedaddy
02-09-2006 18:32:29
 Re: Re: Re: how do you unfreeze an engine in reply to 86 camaro z28, 02-09-2006 18:19:27
Hate to tell you but there's only one way, tear it down and rebuild it. It only takes a few revs with no oil to shell a engine!
Good luck, Ron
86 camaro z28
02-09-2006 19:50:43
 Re: Re: Re: how do you unfreeze an engine in reply to ricedaddy, 02-09-2006 18:32:29
is it easy ron let me know its a chevy 350 in a 86 camaro
Rick K
06-09-1999 10:00:39
While your waiting for more advice, squirt some Kroil or other penetrating hole into the cylinder(s) thru the spark plug hole(s). It won't hurt, and at least you will actually be working on the problem while you are gathering more specific info
