CAV Injector Pump Problem
doogdoog
08-24-2002 19:28:09
Aloha, I have a CAV fuel injector pump which is from a 4 cyl diesel engine and cannot get fuel to the high pressure side. I have bled all the connections to the pump but nothing comes out when cranked. I tested the shut off solenoid and it works ok and I even removed the plunger from the solenoid but no difference.Is there anything that I can do before I take this thing apart???? All suggestions will be appreciated.
Mahalo,
doogdoog
ken
06-29-2003 13:00:40
 Re: CAV Injector Pump Problem in reply to doogdoog, 08-24-2002 19:28:09
chek drive gear and shaft pin
Simon Thomson, Scotland UK.
02-16-2003 14:23:14
check out this link. If it doesn't work go to www.semidiesel.com and search the online manuals.
Regards Simon.
