HELP!! McCormmick M starting problems
Dan Lawrence
08-29-2002 14:11:55
I have a 6hp M that refuses to start. I've checked the mag and it is hot. It will fire if I put a little gas in the intake. I checked the needle valve and pickup tube and the are both okay. I put new rings in but the intake valve seems to not open. I've tried loosing the intake nut and tightening it. The timing is where it should be. I'm about ready to dig a hole. Any ideas?
Tom
08-29-2002 19:28:51
 Re: HELP!! McCormmick M starting problems in reply to Dan Lawrence, 08-29-2002 14:11:55
Seems to me that you answered your own question. The intake valve has to open, for the engine to get any fuel. If it isn't opening, the engine will never run.
Baggsy Wy
08-31-2002 10:40:31
 Re: Re: HELP!! McCormmick M starting problems in reply to Tom , 08-29-2002 19:28:51
Do you have a manual for it? Hit and Miss enterprises has them and they are not expensive at all...reprints but it should cover what you're needing, and if you do dig a hole, can you put it in my back yard???
Dan Lawrennce
08-31-2002 16:06:34
 Re: Re: Re: HELP!! McCormmick M starting problems in reply to Baggsy Wy, 08-31-2002 10:40:31
I finally found at least part of the problem. The 6hp engines used water in the carburator to help keep the engine from knocking. I drained the water out of the hopper and found that water was leaking into the head between the carburator. Once this was fixed, it would run but it still needs more work. Thanks for all the help,
Dan
