Montgomery Ward Powerlite Electric Plant
Bob Folkerts
09-06-2002 14:15:08
I hope you folks can point me in the right direction. I've used the John Deere and Ferguson Forums extensively in the past and they have been extremely helpful. My newest project is a little different and I've jumped into it in total ignorance. I have a Montgomery Ward Electric Plant not sure of the vintage but would guess 40s or 50s. Mice have chewed up and just about destroyed the wiring and consequently I need a wiring diagram and or owners manual of some sort. It looks like I'm going to need a few parts also but would like to know what it is I'm looking at before I start hunting. The plate on the side reads Montgomery Ward Powerlite Electric Plant Model 64MX4934A-1 Serial No. 66 298616 I don't know who made the motor but it is a single cylinder air cooled unit with a 12 Volt System. The generator is Single Phase, 1000 Watt 115 Volts and either 5.7 or 3.7 Amps (couldn't tell for sure) Gen No. 275324 Gen Data 5017 ??? Any help or direction you could give me would be greatly appreciated.
Thanks in advance
Bob
Stiffy
12-27-2005 18:46:32
 Re: Montgomery Ward Powerlite Electric Plant in reply to Bob Folkerts, 09-06-2002 14:15:08
Bob, i just traded for a simular outfit already restored and running. Let me know if you want to look at it and do a drawing of the wireing. I am located in westcentral Indiana.
GARY L. COMSTOCK
04-09-2003 02:05:21
I HAVE A TWO CYL. WATER COOLED MONTGOMERY WARD 3000 WATT GENERATOR THAT IM TRYING TO GET GOING I NEED A MANUAL AND SOME HELP IT HAS ELECTRIC START THAT WORKS. THE CARB AND GAS TANK ARE A LITTLE GUMMY AND I THINK THE IGNITION SYSTEM WORK ONLY IM TRYING TO FIGURE OUT HOW IT CAN FIRE TWO SEPERATE CYLINDERS WITH ONLY ONE SET OF POINTS THAT ONLY OPENS AND CLOSES WITH ONE REV.PLEASE HELP I WILL GET SER. AND MOD. NUMBERS IF NEEDED.
Simon Thomson, Scotland UK.
02-15-2003 18:41:57
Put the post you have here on sparkarcs, which is one of Harrys forums. Prompt replies a certainty.
