Petter A1
Alan
09-19-2002 13:17:27
I have a 1948 Petter A1 that used to run quite well . I decided to steam clean it and it hasnt run since . The Mag is dry and sparks well , the shock I got off it was awesome !!
It appears to be sucking in the exhaust and blowing out of the carb..does this make sense?
Any help would be greatly appreciated
James Grice
03-20-2003 11:44:48
 Re: Petter A1 in reply to Alan, 09-19-2002 13:17:27
It looks to me like a very common petter engine problem. I would remove the cylinder head and make sure that the exhaust valve has not seized open. This will explain the problem because it causes the engine to make confusing sucking and blowing noises when turned over. It is probably not blowing from the carb at all.
P.S. I have bought and restored 6 petter engines and every single one when purchased has had a seized exhaust valve!!
Simon Thomson, Scotland UK.
12-14-2002 17:56:28
I'm going to state the obvious here but did you swap starting handles. I spent weeks on and off trying to get a J.A.P. 55 engine running before realising I was turning it over the wrong way. I have three identical starting handles, two go one way and one goes the other, and you guessed it, I used the one that goes the wrong way!!!!!
