Briggs Stratton engine
TH
10-02-2002 03:29:49
We have just acquired an aggregate that is approximately ten years old. The engine doesn't work at the moment and we are going to repair it. It is a 16 hp four stroke Briggs & Stratton engine. The engine is nothing like we have seen before. There seems to be a chamber on top of the combustion chamber and a valve separating them. The spark plug is on the upper chamber. When the engine is turned by hand the valve opens and shuts regularly. It must be that the valve opens at the end of the compression stroke and lets the plug to egnite the fuel. Is this true? Could you tell me more about this? Why it has such a structure?
Also the rpm governing system seems to be jammed. How does this system work in B&S engines? I don't have any detailed information about this particular engine right now. The governor seems to be working by vacuum.
All the help will be appreciated.
German C. Rodriguez
07-21-2004 10:22:36
 Re: Briggs Stratton engine in reply to TH, 10-02-2002 03:29:49
Please Quote:
The Ignition Module for the following Engine:
Vanguard Briggs & Stratton Engine 16 HP, V-TWIN OHV, MODEL 303447, TYPE 1068-A1, P/N. 96122611
Cordially,
German C. Rodriguez
R.C. ACTION
16260 SW. 82 STREET MIAMI, FL 33193
TEL. 305-752-0020
FAX 305-752-0025
Bob
10-08-2002 06:13:17
Is there a model #? I have a Briggs repair handbook that runs from 1919 to 1981, I could find some info for you in there. Think I paid 22.00 at a Briggs dealer for it. Bob
TH
10-08-2002 06:43:16
 Re: Re: Briggs Stratton engine in reply to Bob, 10-08-2002 06:13:17
Thanks for the reply. I've found a book about these engines at the library which already answered some of my questions. I haven't found any model number in that engine but according the book it might be model 346000.
The thing that I thougt about that combustion chamber stuff was a misunderstanding. The piston is not directly under the spark plug. The valve showing is intake or exhaust valve. I don't know how I could have made such a stupid assumption.
Thanks for the help.
John Painter
03-16-2003 10:31:33
 Re: Re: Re: Briggs Stratton engine in reply to TH, 10-08-2002 06:43:16
on my ohv engine,the valve lash is set with the piston 1/4 inch past tdc. How do I set the piston with no special tools? Thanks
