How much is a good running, good paint 11 hp briggs worth? no text
geoff
10-04-2002 15:13:54
hg
Bob
10-08-2002 06:07:45
 Re: how much is a good running, good paint 11 hp briggs worth? no text in reply to geoff, 10-04-2002 15:13:54
Depends. I need an engine to fit into an old Wards (Allis Chalmers). It was a 7 horse cast iron. Is it vertical or horozontal engine? Electric start? What part of the country are you in? My tractor is the Sim-1267A, used a Briggs model 19 with starter/generator combination. I could rebuild if I find a good Crankshaft. If yours could I am interested. Bob
geoff
10-08-2002 13:10:32
 Re: Re: how much is a good running, good paint 11 hp briggs worth? no text in reply to Bob, 10-08-2002 06:07:45
it is virtical but i do have an old cast iron briggs with a good crank, cam, tappets, and block but no rod or piston, i would be willing to sell it dirt cheap ($10) i am located in hammond indiana (near chicago)
Bob
10-08-2002 18:30:31
 Re: Re: Re: how much is a good running, good paint 11 hp briggs worth? no text in reply to geoff, 10-08-2002 13:10:32
Sounds good but which crank is important. Is it a 19 model engine? did it have takeoff on both ends? Bob
geoff
10-08-2002 18:33:00
 Re: Re: Re: Re: how much is a good running, good paint 11 hp briggs worth? no text in reply to Bob, 10-08-2002 18:30:31
one end is flywheel other is pto, i dont know the "model" but it was a 14hp
Bob
10-08-2002 18:49:01
 Re: Re: Re: Re: Re: how much is a good running, good paint 11 hp briggs worth? no text in reply to geoff, 10-08-2002 18:33:00
Geoff; I am keeping your email so I can get back to you. I leave for Seattle in the morning and will be gone about 10 days. I will check on the crank but my book shows the Model 14 (may be yours please look for a tag) and the 19 use the same crank. If so I will buy and pay freight. will get back to you, Bob
