Hoof governer
Brad
10-10-2002 17:41:49
I have a Wisconsin V4HD engine. Upon removing the carburator for over haul I discovered a device called a Hoof governer that mounts between the carb and the intake manifold. It has what looks like a throttle plate that is attached to a spring under a plate that is rivited on. I assume there is some kind of vacuum diaphram in there that closes the plate.
Doesn't this engine have a mechanical governer to regulate engine speed?
Can anyone explain it's function?
Brad
Gene Davis
10-13-2002 21:26:52
 Re: Hoof governer in reply to Brad, 10-10-2002 17:41:49
They were also known as velocity governers, they balanced vacuum against spring pressure to regulate engine rpms on lots of older truck engines, also some forklifts used them. Gene
