IHC lbb 3-5 hp engine
David Heggie
10-18-2002 15:48:02
How do i remove the flywheel. I have removed the nut and bolt on the inside of the flywheel and the flywheel is free on the shaft. What do i do now? there seems to be a little lip on the shaft,how do i pull the flywheel off? thanks david
Kelvin
10-26-2002 22:33:42
 Re: IHC lbb 3-5 hp engine in reply to David Heggie, 10-18-2002 15:48:02
If you've got a lip on the end of the shaft you're going to have to file it off. Once the lip is gone the flywheel should pull off. You might have to use a pry bar behind the flywheel, but be careful you're prying on cast.
David Heggie
10-27-2002 07:21:16
 Re: Re: IHC lbb 3-5 hp engine in reply to Kelvin, 10-26-2002 22:33:42
Thanks Kelvin
Patience and more patience. It was not an actual lip only appeared to be so. Lots more wd40 and a large screwdriver at the back and it gave away. once the initial give away the rest was easy. I guess it will be the same for the gib keys. I have a Int m and the flywheels have to come off also. Any suggestion on gib keys?
