LAUSON INFORMATION
BOBBY
10-27-2002 18:16:22
I JUST RECENTLY BOUGHT A LAUSON RSC-591 ENGINE,AND I`M KNEW TO THESE ENGINES,SO I REALLY DON`T KNOW ANYTHING ABOUT THEM OTHER THAN STARTING IT. ANY INFO OR PICTURES WOULD BE APPRECIATED...THANKS BOBBY
Al Briggs
04-24-2005 18:20:18
 Re: LAUSON INFORMATION in reply to BOBBY, 10-27-2002 18:16:22
Where can I find information on an old Lauson Power Products outboard motor (water jet model) serial number 3574178. Al Briggs.
terry l finch
07-07-2004 02:23:18
i got an engine like that in excellent condition. was used as a milking source years ago . whats it worth ? runs perfect.
Ralph Bond
02-28-2003 19:45:04
It seems I have the same motor you have. why did you take the generator off the crankshaft? big mistake!! the generator is what starts the motor. If you still have the generator, clean it up unstick the brushes, you only need two brushes to start the motor. It is a reverse rotation motor. If it is the same one I have it is 12V 300 watt generator. It is between 1908-1909. I am having trouble finding information on mine too. Mine runs, I restored it and built my own contact points and am going to build my own carbeuretor to get rid of the tubular type carb.
If you need any information on how to get yours running, just email me.
Mike
02-07-2003 06:00:37
looking for a coil & condenser Modle # T 653 serial # 8966 W manufacture by Wico
e-mial me with any info.
thanks Mike
Ted Pettus
12-01-2002 09:48:23
I happen to have the same engine but incomplete. Mine had a generator attached. This I have discarted and removed the armature from the crankshaft. My intent is to use the engine for show to my grandchildren. They can examine it to learn how a four cycle works. Is your engine complete? Does it have an ignition system in place?
Ralph Bond
02-28-2003 19:40:38
 Re: Re: LAUSON INFORMATION in reply to Ted Pettus, 12-01-2002 09:48:23
I also wanted to let you know it is reverse rotation motor. If you wish to sell it let me know how much.
