Homelite generator that won't
Mike S
11-17-2002 05:53:59
I just picked up a Homelite generator. used. It has an 11 hp Briggs on it and it runs great, cranks the first or second pull every time. But the generator is not putting out. Obviously the reason for the cheap price. It is less than 2 years old. What should I be checking to see what is wrong? The generator is rated at 5500 watts. Worst case, I can just use the engine on something else, but having a working generator in the winter would be nice.
Thanks
HayWire
12-02-2002 02:05:13
 Re: homelite generator that won't in reply to Mike S, 11-17-2002 05:53:59
Circuit breaker shot, loose wiring, Voltage regulator potentiometer...
bob
11-20-2002 13:35:10
Some of those generators have brushes that need to be replaced occasionally. Usually they can be accessed quite easily from the end of the generator opposite the engine.
Good Luck!
Gene Davis
11-17-2002 20:20:46
Fields may need rexciting, try a local electric motor shop.
Neil Mullins
12-09-2002 16:19:54
 Re: Re: homelite generator that won't in reply to Gene Davis, 11-17-2002 20:20:46
There is a capacitor in the end of them too. check it
Simon Thomson, Scotland UK.
12-14-2002 17:39:27
 Re: Re: Re: homelite generator that won't in reply to Neil Mullins, 12-09-2002 16:19:54
Post on sparkarcs. It's dedicated to antique plants but I'm sure someone will help.
Link
