Cutout relay on wisconsin
chris
12-01-2002 17:27:24
I was wondering if there is a way to adjust the relay? How does the contact points close, if I manually push they hold and charge but how do I test the relay to find out whats wrong? thanks chris
Brian
12-06-2002 09:26:47
 Re: cutout relay on wisconsin in reply to chris, 12-01-2002 17:27:24
Check all of you connections. My CA Allis had the exact same problem. The ARM wire was loose on the generator. I found it in the dark one night. It was glowing because it was so hot.
