Fairbanks-Morse 3 HP Z, 1926
John Burrows
12-03-2002 20:11:45
Can anybody tell me why my engine won't pick up fuel from the tank. It runs from the carb. bowl fine but will not run from the tank.
Van(WA)
12-05-2002 07:16:11
 Re: Fairbanks-Morse 3 HP Z, 1926 in reply to John Burrows, 12-03-2002 20:11:45
John, Your check value is stuck!! that little ball bearing has to go "back and forth", shake the "H" out of it, and then the gas can go on thru. This happens all the time, especially if a engine is not run for quite a while.
Tom
12-04-2002 19:24:33
Got a check valve on the end of the fuel line?
John Burrows
12-04-2002 19:58:09
 Re: Re: Fairbanks-Morse 3 HP Z, 1926 in reply to Tom, 12-04-2002 19:24:33
Yep, got a check valve, such as it is. I ordered one from one of the suppliers and when I got it it was a ball bearing inside a ferrule union.
John Burrows
12-04-2002 19:57:17
