Powerlite generator,engine type?
raycr
12-07-2002 09:31:34
We dug the generator out of Mothers shed, Dad used it for backup power for Ham type radios, he stoped using it years ago. Now, I want to use it but there is no spark, I don't find any brand name on the engine. I would like to find a repair manual for the engine or the whole gen set. The generator info is:
Wards Powerlite
Model# 64mx4934a-1
ser# 66.298655
115 AC volt 8.5 amp 1000 watt
with secondary charging for the starting battery @ 15 DC volts 10 amps
the gen # is 276069 and gen data # 5017 Any info and help getting this old unit up and running would be a great help
Thanks Raycr
GARY L COMSTOCK
04-13-2003 08:40:40
 Re: Powerlite generator,engine type? in reply to raycr, 12-07-2002 09:31:34
HI I JUST PURCHASED A WARDS POWERLITE PLANT MY MODEL IS A 64MX4930-F SER# 96.316949 3000 WATT GEN#285538 I JUST GOT IT RUNNIG THIS WEEKEND AND IT CHARGES 13.5 VOLTS ON THE DC SIDE AND THE 110 WORKS TO. IT WAS SETTING FOR TWENTY YEARS IN A GARAGE. I THINK BY THE LAST 3 SER. #S IT IS A 1949 MODEL. IT HAD A BUNCH OF BAD WIRES ON THE IGNITION SIDE AND I REPLACED ALL OF IT I HAD ONE BAD COIL AND A BROKED PRIMARY WIRE UDER THE GEN. JUNTION BOX IT RUNS GOOD AFTER FREEING UP THE GOVENER AND CLEANING THE CARB AND SEDIMENT BOWL. I AM ALSO LOOKING FOR A MANUAL, IF I CAN HELP YOU WITH YOURS LET ME KNOW.
Joseph Turrisi
12-07-2002 17:07:16
Go to www.enginads.com/sprkarcs.cgi some one there should be able to help you. If you can provide more info about the engine or a picture chances are good that someone there could help you or point you in the right direction.
