Help. cam and mag timing 3Hp F/M
Greg
12-24-2002 06:43:04
Hello and Merry Christmas to all. My question is two part. First, I removed the cam shaft from a 3hp F/M self oiler to free a stuck valve and need the correct position to put it back in. Second the mag gear has a small arrow on the front of the gear which is visible from the view hole on the engine housing. Where should this be in relation to the TDC of the engine to correctly time the mag. Thank you for all your help.
