Wisconsin-Robin Honda info
Gene Davis
01-08-2003 15:34:58
Have come into posession of 2 GX160 5.5 hp (ohv) Honda engines,and one that I am pretty sure is a flat headed Wisconsin-Robin, no name or ID plate on it painted an ugly off-white all over, but seems to only need valves ground and carb cleaned. Looks like Wisconsin-Robin may have changed to Subaru-Robin, is that correct? Any body want to share some information and sources for parts, and manuals for these engines. Want to replace the 5 hp briggs on grandsons go kart with a Honda if it is thought feasible, have been told Honda is relativly trouble free. They have what appears to be an oil filled clutch/reduction gear that looks to be about 2-1.One honda is complete, and the other is missing the carb/air cleaner,they were for concession rental karts. They are basically in good shape and have compression and not beat-up. actually got one fiiberglass bodied kart in the deal with a timing belt drive to axle. Thanks. Gene Davis
