Help with egine ID,,,
Mike W
01-13-2003 20:16:15
I have a Wisconsin Model AGHD ser#2208055 31/2 x 4 spec #101326 it runs a "Kato-light" genset and is set up for propane,,,, can you tell me the HP and where to find info on the thing,,,thanks very much,,,,Mike
Steve-Maine
01-14-2003 06:47:00
 Re: Help with egine ID,,, in reply to Mike W, 01-13-2003 20:16:15
I couldn't find a Model AGHD in my Wisc manuals but found a AGH and a AGND both have same bore and stroke as your engine and are rated at 12.5 HP. I tried to e-mail you today as I have a repair manual that I could copy for you. Good Luck
Steve
Wayne
01-15-2003 21:48:35
 Re: Re: Help with egine ID,,, in reply to Steve-Maine, 01-14-2003 06:47:00
I was looking at our Wisconsin manuals the other day and if the same holds true for the AGH series engines as the rest of the ones I saw, there was a note in several of the manuals that said that the "D" would indicate that the engine had Stellite (hardened) valves and seats. Other than that difference, the engine would be the same as any other of that same model.
Mike W
01-18-2003 18:50:41
 Re: Re: Re: Help with egine ID,,, in reply to Wayne, 01-15-2003 21:48:35
You are 100% correct on that,,,thanksyou,,,Mike
