Head bolt torque
keith
03-19-2003 15:16:50
hi all, hope someone can help me , i need too know the torque for the head bolts on a wisconsin 2 cylinder engine thd model,spec#265372,serial#4064478,i took the head off because i thought a valve was stuck open,it only fires on one cylinder,the other one has spark but,oil comes out the spark plug hole,seemed like no compression,its getting gas alright valves look good and clean,i don't know what to do next,any ideas would be welcomed,
thanks in advance,
keith
Benjamin J.''Joe Browning
03-19-2003 19:24:17
 Re: head bolt torque in reply to keith, 03-19-2003 15:16:50
Hello, On the other problems with your engine. If you have not gotten one already, go on Ebay and get an older service manual. They are much better then the new ones with a lot more detail. You might also call the factory at 800-922-5632. Ask for Hike, he is very good on helping on problems and parts. Hope this helps. Joe
steve-Maine
03-19-2003 17:08:27
The torque on cylinder bolts are 16-18 Ft-lbs. Sorry I can't help you with other problem
