Positive ID on Wisconsin single
JoeK
04-10-2003 00:36:20
Have WI single cyl engine undergoing restoration.Plate on shroud ids it as BKN,however shroud appears to have been modified and does not seem to fit as it should.Suspect BKN shroud w/recoil may have been adapted to fit.Would any of the block casting marks positively ID engine?
Also it sports a M/S carb,which appears to be OEM from fit.I guess what I'm sayin is that it looks like a BKN,but I would like to be "sure".
Steve-Maine
04-10-2003 02:56:52
 Re: Positive ID on Wisconsin single in reply to JoeK, 04-10-2003 00:36:20
The casting number on crankcase of a BKN is AA-97, Carb. could be a Zenith # 11193 or a Schebler Model VH-53. Hope this helps you.
JoeK
04-10-2003 14:38:44
 Re: Re: Positive ID on Wisconsin single in reply to Steve-Maine, 04-10-2003 02:56:52
Thanks,numbers indicate a BKN,and it does have the Marvel Schebler VH53 carb.Think I'll look around for a "cleaner" blower shroud when I get the rest completed.
