Briggs and straton engine won't start
jeremy
04-18-2003 15:12:39
I have a late seventies briggs and straton engine on a tiller i just replaced the magneto or coil the points and condensor before that I would turn the engine over with my hand holding the plug wire and I would not get shocked. After replacing everything from above I am getting a pretty good shock from the plug wire after turning over the engine but I cannot find a plug not even a new one to produce a spark.
Dave
08-04-2003 08:02:19
 Re: briggs and straton engine won't start in reply to jeremy, 04-18-2003 15:12:39
If you have the plug connected to the wire but the plug is not touching the engine the plug will not spark. make sure the threads of the plug are touching a bolt or some part of the engine block then turn the engine over. You should see a spark then
