Cracked water jacket
Nobul
04-21-2003 17:15:32
I rescued a MH Type 2 from a barn that has had the water jacket completly busted out on the lower side. The cylinder mounts to the base via tabs on the side of the water jacket and the crack is below these so alignment will be maintained. What is the best fix? Welding or brazing. Will require about 20 inches total weld/braze with a couple of small pieces to be fitted up. I do have all the pieces. This seems to be a not common engine so would like to preserve it if possible. Thanks for any responses. Rob.
