2-51 detroit diesel
Travis smith
04-24-2003 22:55:28
I am looking for any info at all on a 2-51 detroit diesel engine I have one that is powering a 12.5 kw delco generator and am looking for a few parts
Michael Carr
02-08-2006 02:38:32
 Re: 2-51 detroit diesel in reply to Travis smith, 04-24-2003 22:55:28
I have a mate that has a 2-51. I have looked at it very briefly. It looks in very good condition but he says it seems to be wanting to run away. I do not recognise the governor which has, by the looks of it, calibrated springs. Do you perhaps have a drawing of the governor linkages?
I'd appreciate someones help.
Regards
Michael Carr
Gene Davis
04-27-2003 19:38:48
John Deere used this engine in their 435 series diesel Tractor in 1959-60, the Deere dealers may have a listing on it.
motrack
04-27-2003 20:03:39
 Re: Re: 2-51 detroit diesel in reply to Gene Davis , 04-27-2003 19:38:48
Deere no longer has parts in their system for these engines.
motrack
04-25-2003 07:39:55
its a 2-53 engine and look in the phone book under diesel engines and find a Detroit Diesel engind dealer. Parts are available
G Taylor
05-04-2003 07:15:31
 Re: Re: 2-51 detroit diesel in reply to motrack, 04-25-2003 07:39:55
Even Detroit doesn't carry part officaly for the 2-53. However 3-53 two valve parts are the same. Purchase the N series 21 to 1 pistons,sleeves and N45 injectors. Starting will be improved and fuel efficiency increased.
Travis Smith (Smitty)
10-09-2004 15:21:52
 Re: Re: Re: 2-51 detroit diesel in reply to G Taylor, 05-04-2003 07:15:31
Thanks for the info. This engine is a 51 series not a 53 series. The 51 series Detroit Diesel has no valves whatsoever and is a "true" 2 stroke engine. Detroit made this engine for only a few years in the 50's. If you know of anyone who has parts for this engine, please let me know. I have pictures of the engine if you would like to see them. Smitty
G Taylor...........more
05-04-2003 12:34:39
Don't make the cheapo mistake that many do on compression ignition engines which require all the heat and pressure they can get to start. Grinding the valves and seats just sinks them increasing the combustion chamber volume. Doesn't look like much but it's a sizable percentage loss. Always purchase new valves and seats.
