Briggs screeching noise
John
05-09-2003 09:11:56
Hello
I just changed the points in a small 3 hp briggs. Problem is .. now after I put it all back together and start it .. I hear very loud screeching noise then the engine seems to lock up and ... It appears that the fly wheel key was sheared off.. what causes this to happen???? any help would be greatly appreciated....Thanks John
R. Green
04-23-2004 11:53:49
 Re: Briggs screeching noise in reply to John, 05-09-2003 09:11:56
REPLACE the starter rewind assy. Dealears have this part for under $20.00. Flywheel key can't be sheared off cuz it wouldn"t start..
R Smith
05-11-2003 10:02:59
did you tighten the rewind assembly really good? also check inside the assembly and look for rust on the ball bearing.just a few things to look at.R Smith Tex
