Need info on restoration Fuller Johnson Model NC engine
C. W. Cooke
05-21-2003 14:01:35
I have recently acquired a Fuller & Johnson Model NC 2 HP (1926-1927 model) with WICO magneto and have no idea how to proceed with cleaning, parts etc.
C. Cooke Jr
05-22-2003 13:23:58
 Re: Need info on restoration Fuller Johnson Model in reply to C. W. Cooke, 05-21-2003 14:01:35
Thank you. Do you use gasoline or fuel oil? If gasoline, does it need to be treated in some way?
Plain Old Gasoline
05-23-2003 19:44:57
 Re: Re: Need info on restoration Fuller Johnson M in reply to C. Cooke Jr, 05-22-2003 13:23:58
Straight from the pump. Same as you would use in your car. Some old engines are set up to run on kerosene, but this isn't one of them.
Try A Vacuum Cleaner....
05-21-2003 15:56:32
 Re: Need info on restoration Fuller Johnson Model NC engine in reply to C. W. Cooke, 05-21-2003 14:01:35
Actually, go to www.enginads.com, and post your question on the Smokstak Board. Copies of the owner's manual are available from Starbolt Enterprises, listed on the Site Sponsors page.
